error code
Does anybody know what error code E H-4 for this forklift model ?
  • Posted 27 Sep 2022 23:44
  • By Juan_Hernandez
  • joined 27 Apr'21 - 1 message
Error codes H4-1, H4-2, H4-3, H4-4
Turn the ignition key switch OFF,
disconnect the battery negative
terminal, replace the attachment 1
lever potentiometer with the
attachment 2 lever potentiometer,
and check if there is any change in
the error.
H4-*
H3-4
Installation defect
Attachment 2
lever potentiometer abnormality
H3-1·H3-2·H3-3
Inspection 2:
Harness continuity and short circuit
inspection
NG
OK
Harness defect
Fuse inspection
OK
Replace fuse
NG
SAS/OPS/mini lever
Inspection 1:
Attachment 2 lever potentiometer
inspection
NG
OK
No error
Error
Connector contact defect
Disconnect the battery negative
terminal, after inspecting and
correcting disconnect and water
entry of A21, A23, AO3, XO2, YX1
and Y3, reconnect all connectors
and the battery negative terminal,
turn the ignition key switch ON,
and check whether or not there is
an
  • Posted 18 Nov 2022 13:35
  • By delga76
  • joined 20 Oct'16 - 22 messages
thanks
H-4 codes are errors for the 4th lever, attachment
H-3 side shift
H-2 Tilt
H-1 Lift
  • Posted 30 Sep 2022 06:20
  • By John50
  • joined 7 Sep'19 - 155 messages
  • Netherlands
should be more to the code than that. no codes shown in the manual for that
  • Posted 29 Sep 2022 01:46
  • By Nwrecchian
  • joined 18 Aug'22 - 19 messages
  • Maine, United States
Mitsubishi FD200
Tusk 350CGH20
October 13-15, 2026 - Shenzhen City, China
November 10-11, 2026 - Auckland, New Zealand
June 17, 2027 - Nottinghamshire, United Kingdom
Phytoplankton create at least half of the world's oxygen production, despite amounting to only about 1% of the global plant biomass. They also respond rapidly on a global scale to climate and environmental variations, so are often used as indicators of marine health.
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
edition #1297 - 3 September 2026
In a move intended to provide Pakistan with a basis on which to compete with its global peers as a modern trading economy, Hutchison Ports Pakistan will spend $76m on a major upgrade and electrification of the cargo-handling equipment at its Karachi facility... Continue reading
