error code H8......2B
In Raymond DSS350
I have problem with code H8 DRIVE SHOTDOWN.
The traction motors and regen card is good.
Exchange position the current sensors (hydraulic and traction )
and the code now is 2B
Someone has had a similar problem ??
thanks!
  • Posted 14 Aug 2014 13:09
  • By richardson
  • joined 15 Apr'13 - 6 messages
  • n.l., Mexico
ah so you did get a 6t. that was kind of important.
  • Posted 21 Aug 2014 06:49
  • By stam
The team is now ready!
exchange current sensors
traction to lift
and I showed codes 6R, 6S, 6T
and did not work LIFT or TRACTION.
The problem was solved by changing the current sensor
Part No. 223-000-137/001.
THANKS!
  • Posted 21 Aug 2014 05:13
  • By richardson
  • n.l., Mexico
dss350 has that long vehicle manager, gray or black.
the current sensors are swapable but if the traction was bad and put in the lift place you should have code 6t not 2b so i don't think your current transducers are the problem, you may have a 2b code now from something being put together wrong or power cable routed through the sensor the wrong way.
have you tested the transistor modules inside the vehicle manager? tm3 and 4 are going to be worth looking at after getting 2b to go away. good luck
  • Posted 20 Aug 2014 07:53
  • By stam
I think you are referring to the power amps? You swapped amps? Or Prox? If problem followed then you know it needs that amp or prox
  • Posted 19 Aug 2014 13:30
  • By EasiTek
US forklift tariffs now 15% Washington, DC, United States
edition #1285 - 11 June 2026
