Toyota 8FGU32:
Error Code E67-1, and Clearing Toyota Codes
I am working on this Toyota 8FGU32, and it is displaying a E67-1 error code, I checked the mast sensor, and harness, they appear to working correctly, I disconnected the battery, cleaned up the terminals and posts, assuming this would be enough time to clear any codes, but the code is still present on the display, I tried the 5 cycles of the accelerator pedal, but still no luck.
There does not appear to be any ill effect to the code, other than being a nuisance code scrolling across the display.
Any thoughts, tips or suggestions?
  • Posted 14 Feb 2014 01:39
  • Discussion started by Wajaxed
  • British Columbia, Canada
If it wasn't for human error and negligence, I would have nothing to do most days.
Stay safe
Ed
how did you solve this issue i have a unit having the same issue.
  • Posted 23 Nov 2022 02:18
  • Reply by ANDREW_WORLEY
  • Oklahoma, United States
Yep, that is a faulty cpu board.
You can sent it to TVH if possible, they can fix it for a good price ore sent you a used one.
  • Posted 8 Mar 2020 03:42
  • Reply by John
  • Netherlands
johnengels2@hotmail.com
hi john,i am suspecting to have a faulty cpu because i got the cpu on the forklift which is giving me errors then i plugged the same cpu on the forklift which is working but the same error(E67-1) still popped up,can it be a faulty cpu?
  • Posted 8 Mar 2020 03:12
  • Reply by matel
  • Zambia
67-1 is the lift height sensor, check the cable conection between mast and body, you can disconnect the sensor and see if any other error pops up. There are 3 wires. (normaly open and normaly closed)
You can,t clear the errorlog, when error is fixted the display will not show the error.
  • Posted 8 Mar 2020 02:05
  • Reply by John
  • Netherlands
To clear the errorlog, just disconnect the - side battery for a minute.
  • Posted 8 Mar 2020 01:59
  • Reply by John
  • Netherlands
i am also experiencing E67-1 on my toyota forklift FBEU15,how did you manage to clear out the error?
  • Posted 7 Mar 2020 02:05
  • Reply by matel
  • Zambia
Louisville, KY, United States
Dubuque, IA, United States
Terberg YT223-4X2
UN Forklift FBR25NQC3
Linda Häkkilä Linda Häkkilä
