Error code E44
Can anyone tell me what this is? The manual only goes to E43. I have an E44 flashing.
  • Posted 22 Apr 2015 11:11
  • Modified 22 Apr 2015 11:16 by poster
  • By garu_d
  • joined 5 May'12 - 4 messages
garydennie@yahoo.com
so how do you about check sensor i have the same issue
  • Posted 17 Nov 2020 13:22
  • By darren_m
  • joined 24 Jun'16 - 3 messages
  • Posted 6 Nov 2020 13:58
  • By darren_m
now you see why we suggest putting it in signature in profile...
forum strips all url's and email addresses when put in the open forum, it has to go in profile but i see you did that, good deal.
ygm :o)
hope it helps you figure out the problem
good luck
  • Posted 24 Apr 2015 21:16
It's done... [email address removed].... and thank you.
  • Posted 24 Apr 2015 15:47
  • By garu_d
you should put your email address in your profile signature
i have some info to send you
  • Posted 24 Apr 2015 13:40
Serial # AF17D31906
  • Posted 23 Apr 2015 04:00
  • By garu_d
serial number off data plate?
there is a heat plus knowledge service doc on this error code also
  • Posted 23 Apr 2015 03:23
thank you
  • Posted 23 Apr 2015 00:49
  • By garu_d
Its for the Absolute Pressure Sensor. It's located above the oil filter and is mounted to the oil pump drive. Should have a 3 wire connector.
  • Posted 22 Apr 2015 13:10
  • By JimConnected
  • joined 23 Jun'11 - 15 messages
Maxlion MTF25-60-2WD
Maxlion MTF30-45-2WD
Zhejiang UN Forklift Co., Ltd
