Error code e159
Tried to use pallet jack and got error E159 and nothing works does anyone know what this code means?
  • Posted 31 Dec 2021 01:09
  • By Daveyboy
  • joined 31 Dec'21 - 1 message
David tennant
You can buy a lithium battery from walmart and soldier it in yourself to repair the card. Done many. Rough the surface up on both sides of new battery and be quick at the soldier. Saves 600$+.
  • Posted 2 Jun 2026 10:43
  • By ron_k
  • joined 2 Apr'15 - 144 messages
  • North Dakota, United States
4kliftman
Our 3v battery is reading 0.8, sent the board to an electronic repair shop and there are unable to find a battery with the posts orientated correctly to be soldered back onto the board. Do you have a link to the battery you used?
  • Posted 2 Jun 2026 01:39
  • By Reese_George
  • joined 2 Jun'26 - 1 message
  • ND, United States
Reese
It is the code of just about everything. Can communication error. So several things involving this code. Have the same error on one now and never thought it to be a E-tac issue. But here's some others to check before. First is the red toggle switch.
Make sure it's good. If you have
the keypad, you will have to code
in also to power up if not
disabled. Next is line contactor
coil voltage. If low use toggle on
and off to watch voltage. If every
time it increases, then it's the
lithium etac battery and the card
or battery must be replaced. Is
the gray cable going to the etac
card ok. Also a issue and has a
upgraded part out for it.
Updated repair! First remove the handle controls, and check the lithium battery on the etac card. If below 3v. It has to be replaced. You can just replace the battery for about 5$. Easy to remove and soldier back on. Remember you are working with a battery and heat for the risk!
  • Posted 11 Feb 2022 00:18
  • Modified 17 Feb 2022 23:21 by poster
  • By ron_k
4kliftman
Leonardo Quintero Stollwerck Leonardo Quintero Stollwerck
Senior manager sustainability, KION Group
General manager, Autoquip
VP and CEO, Toyota Material Handling Australia
President and chief executive officer, Toyota Material Handling Australia (TMHA)
