Error code D-75
Hi there, does someone know what is D-75 troubl6 means ?
My unit mode # DP50CN1 S/N AT19E80073.
It's working good, and some time the accelerator pedal inoperative, the RPM won't go up at all, then I turn off and turn engine on again to reset. Can someone help me please ?
  • Posted 12 Aug 2016 04:43
  • By mynor
  • joined 21 Apr'16 - 6 messages
mynor silva
I know the OP posted this a long time ago, but with the recent bump, here goes...
D-75 on these perkins dp50s is usually related to the idle validation switch not switching at the correct time relative to the throttle position ramping up.
I've found its usually either a bad idle validation switch, shorted wiring leading to it, or just mis-adjusted.
The pedal sensor voltage should be about.35vdc at minimum thither and the idle validation switch should be closedat this point, but open with any throttle input. It can take a few tries to find the sweet spot if you don't have the perkins software to view it while adjusting.
  • Posted 26 Nov 2024 10:01
  • By IdahoTech
  • joined 26 Nov'24 - 2 messages
  • Idaho, United States
I have been looking at this for a long time, and no one seem to find anything to fix this error code. I have your same model forklift and i am going to change the throttle position sensor. I think is that. I will advise. In the mid time, have you found anything on it?
  • Posted 28 Sep 2024 22:17
  • By Jdel
  • joined 28 Sep'24 - 2 messages
JD
Did you ever get a response to your question or did you figure out what the problem was? I have the same code and symptoms.
  • Posted 14 Mar 2017 05:49
  • By tyrone_m
  • joined 14 Mar'17 - 1 message
Helloooooooo,,, some body there ???
  • Posted 9 Dec 2016 09:06
  • By mynor
mynor silva
Aichi SR18A
Taylor TT300
USD98,500
Zhejiang UN Forklift Co., Ltd
edition #1294 - 13 August 2026
In this week’s Forkliftaction News, we report on Jungheinrich’s H1 financial results and the reasons it has adjusted down its EBIT forecast for the year... Continue reading
Alogotransiphobia is the fear of being caught on public transport without a book to read.
Aichi SR18A
Taylor TT300
USD98,500
