Error code Ad-2, ad-4, ad-6, cb-2, ad-1, ad-3
Hello. I have problem with a toyota 8FBTE20. Error codes: Ad-2, ad-4, ad-6, cb-2, ad-1, ad-3.
Can somebody please help me? The dealer was here on day and says That all the three AC box i defect. What Is the chance for all the three box Is defect over the night? Where should i start looking? Thanks
  • Posted 29 Jan 2025 08:10
  • By Morten324
  • joined 29 Jan'25 - 4 messages
  • Norway
I will send you an email now.
  • Posted 2 Mar 2025 09:18
  • By Morten324
  • Norway
I can send you the service manual, mail me dacarr83 at gmail dot com
  • Posted 2 Mar 2025 09:03
  • By dacarr83
  • joined 5 May'23 - 11 messages
  • Portugal
Good evening. Maybe i should use more time going over the harness. I find some repair manuals for all the cable on Internett, but the colour and numbers in the different contact isent the same as the draft. How can i find out which cables the can bus use? Excuse for the bad english, but hope you understand?? Thanks for all help and advice.
  • Posted 2 Mar 2025 08:45
  • By Morten324
  • Norway
Thanks for help. I couldent find any lights on mine. I've seen the lights on 7series earlier. I do the meter test and looks fine. Any other ideas? Again, thanks
  • Posted 2 Mar 2025 08:30
  • By Morten324
  • Norway
Good morning, most likely harness defect, ir means can bus is down it should have 60ohm, all the controllers cant comunicate with each other. If you have another equal forklift, you can test each ac drive if its ok. Also check for ground resistence to negative, should be at least 500kohm.
  • Posted 28 Feb 2025 17:46
  • By dacarr83
  • Portugal
There's green lights and or yellow lights that are on each of these controllers. You can swap out these controllers with one another. They act the same way. The lights can tell you which one is bad or all Mark and move them to try and eliminate whether it's a hydraulic motor issue or drive motor issue. Or use a good meter and test between U,V,W. If they are shorted you will have continuity. Between u&v or u&w or v&w. You shouldn't have any. Make sure you remove the motor leads before this test and power is off. Do this for each one. If your lights are steady green on the controller it's not faulty
  • Posted 28 Feb 2025 12:09
  • By ron_k
  • joined 2 Apr'15 - 149 messages
  • North Dakota, United States
4kliftman
