Error Code -93
Can Anyone help with this error code -93?
  • Posted 13 Sep 2016 18:56
  • By Jaymc
  • joined 13 Sep'16 - 2 messages
  • Aberdeen, United Kingdom
Sounds like a EV100 truck. Is the code flashing or is it solid lit?
  • Posted 14 Sep 2016 03:54
  • By BREWSKI
thanks for the info.
The Serial Number is A216A03127V, YOM 1998
  • Posted 14 Sep 2016 00:53
  • By Jaymc
what is the serial number prefix?
there are many of these models that could have the old ev zx panel or the AC controls.
but like brewski said, if it is an older truck with an ev panel then -93 is brush wear sensor code, whatever OEM engineering assigned this code to is the motor brushes for one of the motors, most likely steer motor or hydraulic motor.
I checked the AC status code chart and there is no -93 listed.
  • Posted 13 Sep 2016 23:25
If this is a SCR controlled truck, -93 is a warning for the power steering motor brushes.
  • Posted 13 Sep 2016 22:39
  • By BREWSKI
Yale Lift Truck Technologies
