Error Code 85 & 89
I got error codes 85 and 89. I've searched everywhere on line, but can't find out what they indicate. I turned off the ignition key, waited a minute and the restarted. They codes went away for a couple minutes, then returned. Battery was at 30%.
  • Posted 17 Feb 2016 05:24
  • By JerseyDave
  • joined 17 Feb'16 - 1 message
  • New Jersey, United States
Dave
Both errors refer to low voltage and as you described battery @ 30% I would suspect the battery terminal voltage has dropped too low. Put battery through a full charge cycle and check terminal voltage under full load.
If capacitor voltage drops to <30V for 0.5s then error 85 will occur.
Check fuses and power cables also.
  • Posted 17 Feb 2016 10:01
  • By Roibeard
  • joined 2 Mar'10 - 335 messages
  • Dublin, Ireland
Hyster
edition #1285 - 11 June 2026
Terberg RT223
