Error code 817 only get when frozen
I found that the resistor had a bad wire so I reattached it worked good for one day. Lift is in frozen environment 90% of the time and gets stuck when forks are on second mast and wont go up or down. When it thaws out though it will work for a couple hours. Error code 817 is not in my manual it skips from 816 to 818 so I dont even know what it means. I am thinking it is the encoder that needs to be replaced but I dont like just throwing money at something and hoping it will work.
  • Posted 22 Jul 2019 15:02
  • By Mech40
  • joined 22 Jul'19 - 2 messages
  • Minnesota, United States
Hello,
I am having the same issue a crown HighReach unit.
What was the solution to this issue?
  • Posted 5 Jul 2023 22:05
  • By CANS
  • joined 5 Jul'23 - 1 message
  • Nova Scotia, Canada
KN
Short the thermistor it will start relay for freezer circuit
  • Posted 26 Jul 2019 13:13
  • By dean_f
  • joined 10 May'19 - 6 messages
  • New Zealand
Awesome don't really miss winter but with the heat could always use a reminder
  • Posted 23 Jul 2019 18:17
  • By Mech40
*of course, you have to check this while freezing your a** off
  • Posted 23 Jul 2019 13:41
  • By Ifixit
(1) HGTRS2 is open when FLS is still closed. Check distance between HGTRS2 and mast, correct distance is.20 -.25 in.
(2) Is FLS open below staging? A2.7.4
(3) monitor HGTRS2 input. A2.4.2
(4) check voltage at CA411-4 on Access 4. 13.8v above freelift, 0v below freelift. Could be a bad mast cable
  • Posted 23 Jul 2019 13:39
  • By Ifixit
edition #1251 - 9 October 2025
Todd J Doxsee Todd J Doxsee
Sales operations, Heli
Chief financial officer, Cyngn
Executive vice president and chief commercial officer, East Penn Manufacturing
