Error code 527
Power steering motor was not mounted in and would turn as it was being steered. Finally got the steering motor out after it had stopped working thinking that was the issue but it's still showing 527. I'm sure it is a wire that was broken or frayed from all the extra movement but was hoping someone could tell me what the code was so I knew where to start looking
  • Posted 3 May 2023 00:48
  • By John_Ward
  • joined 3 Mar'23 - 2 messages
  • Michigan, United States
Calibrate steering.
Check harness between LC1 and Access5
Check LC1 mechanical overload limiter set screws should be 0.381mm gap
I would also check FU6
From their it just says replace LC1 then access5.
  • Posted 7 May 2023 23:47
  • By Zerk
  • joined 21 Apr'16 - 28 messages
  • Arkansas, United States
