Thanks jonip. Someone told me about a tool for check the encoder bearing, is it helpful ?
code 52 is 1 may disconnected or broken sensor wires between motor and motor controller. 2 malfunction of motor encoder bearing. when replace the encoder dearing. r u sure u did't damaged any wires ? coz if u did the wrong way it's very easy damaged the wires on the bearing. u better check it. the little cable hv tons of small wires in side.
If you visit the Dealer Locator on the Hyster Americas website and submit your enquiry an authorised Hyster Dealer in your area will contact you.
hyster.com/americas/en-US/Distribution/dealer_locator.htmx
