Error code 52 Hyster E5Z-33
I need some help with this code. I replaced the bearing encoder in motor traction and the code remains and checked all of the wire connected to the controler OK. Any idea ? The serial number is G108V02303B and the traction motor is AC and the pump motor is DC
  • Posted 17 Jul 2009 00:24
  • By luismario_z
  • joined 7 Aug'08 - 14 messages
  • Jalisco, Mexico
servicio@grupozamsa.com
Thanks jonip. Someone told me about a tool for check the encoder bearing, is it helpful ?
  • Posted 31 Jul 2009 08:53
  • By luismario_z
  • Jalisco, Mexico
code 52 is 1 may disconnected or broken sensor wires between motor and motor controller. 2 malfunction of motor encoder bearing. when replace the encoder dearing. r u sure u did't damaged any wires ? coz if u did the wrong way it's very easy damaged the wires on the bearing. u better check it. the little cable hv tons of small wires in side.
  • Posted 29 Jul 2009 11:37
  • By jonip
  • joined 4 May'09 - 11 messages
If you visit the Dealer Locator on the Hyster Americas website and submit your enquiry an authorised Hyster Dealer in your area will contact you.
hyster.com/americas/en-US/Distribution/dealer_locator.htmx
  • Posted 23 Jul 2009 22:12
  • By hyster_europe
  • joined 23 Jul'09 - 1 message
  • Hampshire, United Kingdom
