Clark NPR17:
Error Code -51
We've been getting two error codes on our NPR17. First we were getting -6 intermitantly, but now we've got -51 and we have to unplug the battery to reset the forklift. it does not turn off with the key once the code shows up. The forks go up and down but it does not do anything else.
The on island dealer has not been able to find out the code.... so they say.
Need help. has been down for 2 weeks.
  • Posted 21 May 2011 01:57
  • Discussion started by don_g
  • St. Michael, Barbados
Wondered if you ever got this truck going,am having the same issue with a NPR15,wondered what you found?
  • Posted 4 Mar 2012 02:03
  • Reply by kevin_t
Line Contactor does not close.
POSSIBLE CAUSE
*Defective capacitor.
- Check capacitor bank per component checking section.
- Check for loose or open connections in capacitor circuit.
*Misadjusted / defective steer interlock switch.
- Check to insure that the steer interlock switch closes after
the line contactoh power tips close. Repair or replace.
-Defective steer control.
- Disconnect the positive cable and 4PL plug from the steer
control. If status code disappears, repair steer control.
-Open circuit in capacitor precharge circuit.
- Check for loose connection or broken wire (WHT) at #3 REC
heat sink or along the length of the wire.
- Check for loose or corroded connection at terminal PZ14.
- Check for loose connection or broken wire (BLACK) at 1 FU
power fuse or along the length of the wire.
- Check for loose or corroded connection at terminal PBl.
*Unsuppressed voltage spikes.
- Check that any and all coils, including horns, that are
present on the truck have the proper voltage suppression.
- Check that the static drag chain is present on the truck and
dragging on the floor so that it keeps static electricity
from building up in the truck.
This is for code 51. The 6 code could be an issue with the travel transducer being out of adjustment.
  • Posted 21 May 2011 12:09
  • Reply by rogeriwt
edition #1228 - 1 May 2025
Hoist Liftruck P360-48
Nichiyu FB28PN77B367RRC
Louisville, KY, United States
Dubuque, IA, United States
