Cat Lift Trucks (& Caterpillar) 2EC30:
error code 31
does anyone know what this code means?
  • Posted 11 Oct 2013 05:57
  • Discussion started by seth_c
  • Washington, United States
nobody answer this yet? hmmmm....
well here ya go....
Display = 31: Pump armature transistor emitter fault (low, B terminal). No lift truck operation
you have a problem with connections on the transistor or a bad transistor most likely
  • Posted 26 Oct 2013 22:48
  • Reply by swoop223
VETTER Forks, Inc.
edition #1228 - 1 May 2025
