Error code 23
Does anyone know what error code 23 for a Raymond EASI lift means?
  • Posted 18 Sep 2008 05:46
  • Discussion started by Drizztriveet
  • Wisconsin, United States
www.forkliftaction.com/forum/thread.asp?trid=19916
  • Posted 2 Sep 2017 05:56
  • Reply by stam
Does anyone have the test points for the Q1 transistor?
  • Posted 2 Sep 2017 00:26
  • Reply by jose_z
Never stop learning
FYI this is Raymond part number 828-900-101
Q1 transistor kit
We carry them at Intella Liftparts
  • Posted 4 Mar 2014 06:03
  • Modified 4 Mar 2014 06:03 by poster
  • Reply by M_VANDENTOP
  • Michigan, United States
jonG - Same code replaced Q1 REC. and coded 40 after replacing, told the customer charge the battery and back next day.Battery showed fully chrg. but S.G where 1.240-1.220. Replaced battery now a can sleep!!! Static strap with insulator and a clean battery your set!!
  • Posted 22 Dec 2008 14:48
  • Reply by LOGIC
OK, it's a lift truck. 95% of the time you will need to replacxe Q1/Rec 1 and the power card... Before you do check the cables to the motor, ensure that the insulation has not rubbed through, and that the leads are properly attached. Also check that the batt neg is properly attached to the heatsink (sometimes that will burn off). Please check that the battery is good and not shorted to the frame on both sides (raymonds are sensative to that). Do you have the superword? It will make running the diagnostics easier for the power system.
  • Posted 19 Sep 2008 22:35
  • Reply by JonG
  • United States
Sorry for not including the model, it's a ESAI and the unit won't drive at all, but I can use the lift functions. Thanks for the info so far.
  • Posted 18 Sep 2008 22:53
  • Reply by Drizztriveet
yeah if the orderpicker book i have makes reference to the motor cables too but it mentions improper cable routing
its saying that the current sensor isnt seeing the proper current (ct1 on the power card) and the q1 sense circuit isnt seeing the proper voltage for some reason - an open circuit
to test the Q1 youll need a digital multi meter that has a voltage diode test
  • Posted 18 Sep 2008 12:16
  • Modified 18 Sep 2008 12:17 by poster
  • Reply by justinm
Normally Code 23 is a hard fault, and is an open in the transistor circuit. You will normally have to check Q1, and it's related circuit, which is the drive motor, the parts on the heat sink where you find Q1 (Rec1, maybe rec2, c-1 and r-1), and the power card. Normally you will find that Q1 is blown, and the power card is faulted. Q-1 comes witha new rec1 as a kit, change it as well.. Sometimes you will find a lead burnt off of the motor. Good luck
If it's an intermitent fault let us know and we can walk you through the rest of the checks.. It helps to have the complete model and serial #. Do you have the superword as well?
  • Posted 18 Sep 2008 11:37
  • Reply by JonG
  • United States
you need to post the model and serial number (at least the 1st 2 parts of the serial)
but for an orderpicker it means it detected an open in the main transistor circuit upon startup
this may be the same for a reach but im not sure
is the problem intermittent? or is the truck dead with a 23 right when you turn it on?
are you the operator? owner? or a tech?
if youre not a tech id call the raymond dealer
  • Posted 18 Sep 2008 10:49
  • Reply by justinm
Joseph E Creed Joseph E Creed
CEO, Caterpillar Inc
Secretary general, European Rental Association
Chairman of the Board of Directors, UgoWork
Zhejiang UN Forklift Co., Ltd
Mitsubishi FD200
Hangcha 80XENS
Flesherton, Ontario, Canada
Kortrijk, Belgium
East Peoria, IL, United States
FT-Myers/Naples area, United States
St. Louis, MO, United States
