Error Code 17
Hello,
Anybody able too assist with an error code Ive got on a Doosan B35X-7?
Showing on display when attempt too drive in either direction. Contactor Error 17.
Have replaced line contactor but this didnt make any difference as too this error, going to attend again tomorrow but thought I'd ask see if any help?
Thanks
  • Posted 17 Nov 2020 02:53
  • Modified 17 Nov 2020 02:53 by poster
  • By Lordmoss13
  • joined 3 Jul'20 - 17 messages
  • Wales, United Kingdom
Powerlift Materials Handling
Had this fault code. It turned out to be the Key Switch. Fitted a new switch. The code cleared. Truck now working fine.
  • Posted 6 Oct 2022 20:38
  • By ROBERT_Wilson
  • joined 6 Oct'22 - 3 messages
  • United Kingdom
robbienwilson
Main breaker fault
1. Eye alarm code: 17
2. Display alarm code: 17
3. Alarm level: 1
4. Alarm cause: overcurrent on main breaker coil.
In case of alarm follow this procedure:
1. Replace main breaker
2. Replace logic.
  • Posted 29 Jan 2021 07:10
  • By Roibeard
  • joined 2 Mar'10 - 335 messages
  • Dublin, Ireland
Hello,
Has anybody had any issues with wiring harness plugs?
Have the above machine that on the left drive controller if move harness then machines goes mental, no damaged pins on controller and pins all seem to be locked in harness plug, did de-sleeve the loom from plug too harness too inspect but no visual damage?
Thanks
  • Posted 29 Jan 2021 02:29
  • By Lordmoss13
edition #1294 - 13 August 2026
In this week’s Forkliftaction News, we report on Jungheinrich’s H1 financial results and the reasons it has adjusted down its EBIT forecast for the year... Continue reading
