Error code 05B2
Any ideas what code 05b2 means,
the customer complains that it occors after coming off charge.
Thanks
  • Posted 9 Feb 2024 04:22
  • By andrew_k
  • joined 17 Mar'07 - 337 messages
  • England, United Kingdom
I have been to the truck this morning, swapped the battery with another truck and checked the battery settings in the dashboard. The settings are the same on both trucks. Anything else to check?
After a couple of minutes the fault goes away and the truck drives.
  • Posted 11 Feb 2024 01:51
  • By andrew_k
Ok Thankyou I will check the settings with another truck. Probably a battery or charger fault Id guess
Thanks Again
  • Posted 9 Feb 2024 08:50
  • By andrew_k
Good afternoon,
It s an overvoltage error, it means either baterie voltage is wrong in service menu or there is a problem with charger/baterie. Make sure voltage isn t above 52-54v (not sure the limit). You can always compare with other similar forklift.
  • Posted 9 Feb 2024 06:03
  • By dacarr83
  • joined 5 May'23 - 11 messages
  • Portugal
Aichi RX07B
Taylor TT300
