error 65 ep25kpac caterpillar
Hello , We set the parameters for the group 3. still the error code 65 is comming. When we rechecked the values of the parameters which we had seted , there is change in the the value for parameter (battery voltage adjust ,#46 ). Its value becomes 1.5 instead of 80 volts.
Please send me any solution.
send me mail in equiptecworld at gmail dot com
  • Posted 10 Feb 2013 16:46
  • By lishoy_t
  • joined 29 Oct'12 - 70 messages
  • dubai, United Arab Emirates
option #41 sets battery voltage which should be either 72v or 80v
option #46 is battery voltage adjustment which has to be adjusted manually according to the actual battery voltage read by a voltmeter. This allows the display to set the proper voltage range according to the actual voltage from the battery.
when in this option range during setup you can move the direction lever to F or R to increase or decrease voltage increments by 0.01v +or- , and while the direction lever is in F or R you can depress the accelerator pedal to move the voltage increments by a factor of +10v or -10v.
F moves in + direction
R moves in - direction
once you have the correct battery voltage set on the display by what the voltmeter shows then you can exit out of the setup, cycle the power and everything should return to normal.
If you cannot get these settings to set going through the dash access then you will have to use the laptop program.
  • Posted 10 Feb 2013 22:44
UN Forklift FB25N1LZ1
Deborah Baker Deborah Baker
