OM Pimespo XE 18:
Error 53
Machine model XE18 gives error 53 on the screen. Travel and hydraulics do not work. Can you help on the subject?
  • Posted 29 Sep 2021 19:59
  • Discussion started by Seyit_AKCAN
  • Turkey
SEYİT AKCAN
hola la alarma 53 es que tienes activada una de las palancas activadas en el momento de contacto..
solucion.....desconecta una por una las palancas y se quitara el error cuando desconectes la que esta mal..
tambien si tienes consola ZAPI ajusta las teaching hidraulico
Littoral translation - hello alarm 53 is that you have activated one of the levers activated at the moment of contact..
solution.....disconnect the levers one by one and the error will be removed when you disconnect the one that is wrong...
Also if you have a ZAPI console adjust the hydraulic teaching
  • Posted 12 Dec 2022 00:38
  • Reply by manolo
  • Spain
tecnico
Hydraulic function command entered before ignition.
(Except for hydraulic steering).
  • Posted 29 Sep 2021 21:39
  • Reply by andrew_k
  • England, United Kingdom
Louisville, KY, United States
Dubuque, IA, United States
Linda Häkkilä Linda Häkkilä
