Error 48
Error 48 Forward & reverse. error code 21 full trottel.
no reaction on contactor,
  • Posted 15 Sep 2017 00:00
  • By mikael_j
  • joined 14 Sep'17 - 6 messages
  • sweden, Sweden
micke@tj-s.se
thank you
  • Posted 11 Oct 2017 23:52
  • By mikael_j
  • sweden, Sweden
micke@tj-s.se
There are 2 large pig tail diodes mounted in the heat sink on the SCR panel. Looking at the panel with the control card on top the left diode is number 3.
  • Posted 11 Oct 2017 23:46
  • By BREWSKI
  • joined 10 Jan'12 - 1,698 messages
hello where is the D3 diode?
  • Posted 11 Oct 2017 23:28
  • By mikael_j
  • sweden, Sweden
micke@tj-s.se
hello i checked the contactors for welded tips , where is the d3 diode?
how do i check it ? i have a diode close to a contactor is it D3? /micke
  • Posted 15 Sep 2017 23:30
  • By mikael_j
  • sweden, Sweden
micke@tj-s.se
If this is a EV100 control system you need to check the directional contactors for welded tips. Also check D3 diode for short. The 48 code occurs when voltage at T2 is greater than 88% of battery voltage.
The 21 code is for a throttle pot out of range.
  • Posted 15 Sep 2017 07:12
  • By BREWSKI
The dot above a lowercase "i" or "j" is called a tittle.
ORDER PICKING
FLEET MANAGEMENT
HIGH-CAPACITY FORKLIFTS
CHARGING INFRASTRUCTURE
SAFETY SOLUTIONS
October 12-15, 2026 - Detroit, MI, United States
October 22, 2026 - Sydney, Australia
January 26-27, 2027 - Balikpapan, Indonesia
Kelly Stewart Kelly Stewart
vice president of human resources, Big Joe Forklifts
Board of Directors, UKMHA
at-large director, AED
COO, Intelligrated, Trew and Transnorm
