ERROR -48 YALE
I am looking for some help with the below truck
YALE - EFGV16AAFG100493DZ - A814A01542T
It has a general elctric system, I have a book for an EV100 type and error coed 48 states wrec 3. However this particular truck does not have the EV100 system in it and i was wondering if the fault codes were the same. If they are can someone please tell me which one is wrec 3.
Thanks
  • Posted 26 Jun 2010 00:37
  • By katy_a
  • joined 7 May'10 - 2 messages
  • United Kingdom, United Kingdom
only somewhat (lower numbers <20) are the same
I would pull the battery out and clean all the corrosion and replace any cables that have been laying in the corrosion as a first step,
for code 48 I have; "Look Ahead" test for A2 volts less
than 12% of battery volts.
POSSIBLE CAUSE
Check for short circuit from the motor armature
to the frame of the vehicle.
Defective control.
*= Replace controller unit.
so if you have a very clean armature to frame you may be going to purchase a not inexpensive controller, but I sure would make sure all the power cables were isolated from the frame electrically..
  • Posted 26 Jun 2010 07:37
Lee Rushton Lee Rushton
December 03, 2025 - New Delhi, India
