error 4:182 BT RRE 160
Hello, I have a problem with error 4: 182 on BT RRE-2014. The truck stops raising, shows error 4: 182 and indicator arrow up.
Can anyone help me?
Thank you in advance.
  • Posted 15 Mar 2017 21:06
  • By jollydjoger
  • joined 8 Jun'13 - 23 messages
  • Sofia, Bulgaria
Is it possible to report a malfunction 1:415 bt rre160
  • Posted 18 Dec 2024 04:25
  • By Emad_Omara
  • joined 26 Sep'22 - 5 messages
  • Saudi Arabia
Emad omara
  • Posted 18 Dec 2024 04:24
  • By Emad_Omara
  • Saudi Arabia
Emad omara
Hello
We had the same problem. Chain was adjusted and problem was solved.
  • Posted 4 Jul 2023 21:20
  • By Saji
  • joined 4 Jul'23 - 2 messages
  • Qatar
SAJIN
Hi, first of all you have to check encoders B18 & b19 &, sensors b46, b57&b58. If everything is ok you may try changing parameter 1273 and mast transition valves calibration. I had same fault, swapping between 180, 181& 182. I did it and it was true for me.
  • Posted 12 Apr 2022 17:49
  • By Ferlektric
  • joined 13 Nov'20 - 13 messages
  • Spain
Hi, is there anyone here that has solved the issue with 4:182??? Please tell me if you found some solution. I`ve tried ti change the wire that messures the hight and done a software update.
  • Posted 1 Dec 2021 00:54
  • By Missmee
  • joined 1 Dec'21 - 1 message
  • Sweden
i have the same problem. it have been changed between 4:181, 4:182 and 4: 180... i checked all sensors and wire... now i am testing the valves coils.
  • Posted 2 Apr 2018 09:38
  • By raphael_b
  • joined 2 Apr'18 - 2 messages
  • mato grosso do sul, Brazil
Had the same problem. Checked everything as per workshop manual, i.e height encoder, cable, software version etc. Called out Toyota who proceeded to spend 1 month trying to identify fault. Observed them changing controllers, changing hydraulic valve settings, upgrading software..... After 1 month they fixed the problem and told me the problem was wear in the lift chains and solved by adjusting them!
  • Posted 16 Oct 2017 00:25
  • By Roibeard
  • joined 2 Mar'10 - 335 messages
  • Dublin, Ireland
You can check the basics like the metal sensor bar, bowden cable & height counter for psychical damage.
I would disconnect the battery then check the electrical connectors at the height counter assembly.
If you had a BT CAN service key you could have looked at the diagnostic screen & see what the height counter channels & sensors are doing as you operate the truck.
FWIW: Since the RRE first came out back in 2009, ive only ever changed 1 height counter for an electrical fault - there normally bulletproof.
  • Posted 17 Mar 2017 03:06
  • By Forkingabout
  • england, United Kingdom
Thank you for the information. I have no BT CAN. Will I be able to do without him?
  • Posted 16 Mar 2017 18:57
  • By jollydjoger
  • Sofia, Bulgaria
4:182 = No pulses from the free lift height sensor on lift/lowering.
Either defective free lift height counter assembly, the bowden cable is loose or there is a wiring fault.
Also check the metal sensor bar at the bottom of the mast as these can get bent & upset the sensor that activates the height counter.
Do you have a BT CAN service key?
  • Posted 16 Mar 2017 03:53
  • By Forkingabout
TCM FD115-3
SMV (Konecranes) 20-1200B
