Dear all
Kindly help me, our forklift (Jungheinrich ETV 216 S/N: 91066669) shown an Error for 34 & 85.
Please Explain what must we do, so our forklift can be running normally
Regards,
Lina Marlina
PT. Raya Indo Fortuna
lina(@)indoforklift(.)com
I would first check the ignition switch. unless one pin connected to report the error 34,85
Dear Nemanja_k
Many Thanks for your information.
Regards,
Lina Marlina
www.indoforklift.com
Error 34 Can bus damaged
Error 85 Power release low voltage
If is with wiring all ok on the look probably is defective some component like traction electronic unit or hydraulic or steer.
My suggestion is next
Give that forklift someone who know how to measure is it some unit good or not.When you have that men on machine he can tell what is of component defective.
Change unit will effect that machine again work normally,but only when is all synchronized using PC.
Good Luck
