Error 261
Hello,
tomorrow I will work on Crown WAV60 for the first time.
I don't have any technical docs about it. Does it still have Curtis controller?
Active error is 261. Can you send me error description?
It also had errors 221 and 412 before, but it worked.
Can you send me description of these errors?
  • Posted 27 Nov 2018 00:42
  • By ivanlinaric
  • joined 16 Jan'11 - 110 messages
  • Zagreb, Croatia
Service technician.
Feel free to contact me at ivan.linaric@okretnimoment.hr
You're spot on for this one Techno_nz. It was a broken wire in mast cable.
I managed to use one "not-used" wire so it works now but the customer should get new cable of the warranty. The machine is only three months old and has 26 hours.
Overall, I'm not sure that I like how WAV60 wiring is built and routed.
Somehow it looks like a step back from WAV50 to me.
  • Posted 5 Dec 2018 20:44
  • By ivanlinaric
  • Zagreb, Croatia
Service technician.
No, it has Crown Access 1/2/3 system. No handset required, which is good. check your email. Regards 412, there are two encoders per drive motor. One is connected to Access 4 in the platform, one to Access 2/3 in the base. The access units talk to each other over CAN and compare the encoder readings, any variation and unit stops. Unfortunately there is an issue with WAV60 mast cables, there is a bulletin available regarding the issue (cable cores break or go high resistance). Have had probably 10 WAV60's with this issue and encoder count mismatch or other CAN issues. Some with less than 100hrs use.
  • Posted 27 Nov 2018 17:09
  • Modified 27 Nov 2018 17:14 by poster
  • By techno_nz
  • Canterbury, New Zealand
Briefs United States
VETTER Forks, Inc.
