ENTRANCE BEAM LOCKED
I HAVE A RAYMOND EASIR40TT, FAILURE A FOTOELECTRIC SENSOR AND THE DISPLAY APPEARS "ENTRANCE BEAM LOCKED" IS POSSIBLE SIGNAL BRIDGE FOR USE ALREADY ADVANCING BUT WITH SLOW SPEED
  • Posted 25 Jul 2017 03:17
  • By juan_v
  • joined 25 Jul'17 - 1 message
  • estado de mexcio, Mexico
Showing items 1 - 15 of 15 results.
2013 model here same issue sensors got wet not able to fix......possible to wire short cut bypass them?
  • Posted 19 Apr 2024 03:16
  • By kingkuality
  • joined 21 May'17 - 63 messages
were you able to get truck running without them....im in same situation
  • Posted 19 Apr 2024 03:05
  • By kingkuality
So if I remove them, do I just disconnect the sensors like cut the wires and that's it? It won't show the code nor sound the alarm?
  • Posted 16 Feb 2022 10:53
  • By JoeMar
  • joined 18 Oct'16 - 14 messages
forkliftstech@gmail DOT com
Hello, So if I remove it from the truck it will no longer show the code 8A and not affect truck performance? I can see there are 4 sensors. 2 on each side and can be accessed with allen screws.
  • Posted 16 Feb 2022 10:30
  • By JoeMar
Thanks again!
  • Posted 13 Feb 2018 15:30
  • By gregk
  • joined 10 Nov'15 - 15 messages
You'll have to call the local dealer and explain what you want done. Laptop and passkey needed for this, dealer only.
  • Posted 10 Feb 2018 11:38
  • By stam
Ez-A02-24786
  • Posted 10 Feb 2018 07:40
  • Modified 10 Feb 2018 07:41 by poster
  • By gregk
What is the truck serial number?
Older units possible to jump out. Newish units laptop req'd.
  • Posted 9 Feb 2018 23:47
  • By stam
Stam,
I found the entrance sensors. Even though you directed me to the location, they were hard to find. I cleaned them but no luck. Can I short them somehow or turn them off? Thank you
  • Posted 9 Feb 2018 16:20
  • By gregk
Anytime!
  • Posted 9 Feb 2018 05:16
  • By stam
Thank you so very much. This has been driving me crazy. Youre awesome!
  • Posted 8 Feb 2018 15:40
  • By gregk
right where you enter the truck they are there. where the paint turns from red to black. photo cells pointing across operator compartment so if there leg or ankle is sticking out the truck goes slow and beeps.
  • Posted 7 Feb 2018 09:19
  • By stam
Can anyone give me the location of the entrance beam. I can't find the sensor to clean it. I have a maintenance manual i found it in a schematic but it does not give the location. I have visually inspected but cannot find it. Any help please. This thing is useless without cleaning or removing it. Raymond Easi40.
  • Posted 7 Feb 2018 05:38
  • Modified 7 Feb 2018 05:39 by poster
  • By gregk
I get the same code. Where is the entrance beam located?
  • Posted 3 Feb 2018 18:15
  • By gregk
The photo eyes get dirty sometimes.
I think I understand your question... yes it can be removed from the truck it is optional equipment usually only sold to Home Depot.
  • Posted 25 Jul 2017 20:45
  • By stam
Rabbits can see behind themselves without moving their heads. Because their eyes sit on the sides of their heads, rabbits have an enormous field of vision that helps them spot predators from nearly every direction.
