Linde (& Baker) H50D:
engine runs at one speed
the lift operates fine but always stays at one RPM speed. drives only at one speed and when using the hydraulics the engine doesn't rev up at all. no codes coming out on display. tried adjusting the speed sensor and got the lightning bolt and trouble code 245 to apear. so we adjusted the sensor back to comfirm it was working. any ideas ???
  • Posted 8 Mar 2014 07:00
  • Discussion started by Roadking
Hi Swoop do you have a procedure for adjusting/checking the pedal sensor?
  • Posted 22 Aug 2018 06:36
  • Reply by forktime
  • Alberta, Canada
Recalibrate tilt angle sensor
  • Posted 19 Mar 2017 00:21
  • Reply by edward_m
doubt its anything to do with the ring gear
since he ruled out the speed sensor i would be checking the pressures from the pump since these units are mostly hydrostatic drive type systems
also check the linkage on the accelerator and the accelerator pot.
If correctly adjusted you should get these readings:
- Pedal full travel in forwards direction: 4.1V
- Pedal full travel in backwards direction: 0.9V
now depending on the model and year some of these units ran at only one engine rpm when drive is activated or the hydraulic levers were pulled if i remember correctly.
I would check the pedal position sensor and also the accelerator solenoid actuator.
Got a full model number to go with that serial number?
  • Posted 18 May 2015 08:59
  • Modified 18 May 2015 09:22 by poster
  • Reply by swoop223
Its possible the swash plate has been reset to a slower speed, need a lap top to check.
  • Posted 18 May 2015 06:08
  • Reply by edward_m
Missing/worn teeth can cause a miss count on the speed sensor which causes the engine to run at one speed
  • Posted 13 Oct 2014 19:01
  • Reply by little_forker
we have changed and adjusted the speed sensor. what would I look for on the ring gear?
  • Posted 10 Oct 2014 20:29
  • Reply by Roadking
Check the engine speed sensor and ring gear.
  • Posted 10 Oct 2014 16:35
check the turbo
  • Posted 9 Oct 2014 05:32
  • Reply by kevin_k
Hi
Did u sort this as I'm having same problem.bought one as non runner. Got it running but won't Rev when call for hydraulics
  • Posted 9 Oct 2014 01:18
  • Reply by sean_l
  • Shropshire, United Kingdom
vw diesel lift turbo charged
  • Posted 11 Mar 2014 21:11
  • Reply by Roadking
this is LPG powered truck?
VW engine?
or diesel?
  • Posted 11 Mar 2014 21:02
  • Reply by swoop223
ser# H2X394T00245
This is all I have hope it helps.
Thanks,
  • Posted 10 Mar 2014 22:42
  • Reply by Roadking
going to need more than just that generic model number
need the whole model number and whole serial number to get accurate info so we can help you.
Newer models usually have an 02 or 03 , some digits after the H50D part
and the serial contains the series number we'll need
  • Posted 8 Mar 2014 23:22
  • Modified 8 Mar 2014 23:23 by poster
  • Reply by swoop223
St. Louis, MO, United States
Johnston, IA, United States
Jefferson, WI, United States
Hangcha 78XEN
Flesherton, Ontario, Canada
UN Forklift FB25N1LZ1
edition #1234 - 12 June 2025
