engine light on
how do you retrive codes' on this unit exhaust stinky light comes on at idle trim valve not viberating at idle
  • Posted 13 Nov 2012 00:18
  • By BarrenForklift
  • joined 16 Nov'08 - 14 messages
  • Kentucky, United States
Any chance you know what the codes 91 and 26 are for G25P-3, thanks
  • Posted 18 Mar 2021 09:30
  • By Otterwork
  • joined 1 Dec'18 - 3 messages
  • Manitoba, Canada
updated software replaced trim valve fixed
  • Posted 13 Mar 2013 00:09
  • By BarrenForklift
Check connections at accell pedal,also have seen code come up due to poor connection at SECM (check for ty wrap around connector that should not be there).If connections OK, the SECM may need to be flashed (updated with laptop).
  • Posted 21 Feb 2013 23:53
  • Modified 22 Feb 2013 00:03 by poster
  • By snowmonkey
  • joined 13 Oct'12 - 36 messages
  • Alberta, Canada
codes 74 73 69 rebuilt mixer now just have 69 replaced pedal assy still have code 69
  • Posted 21 Feb 2013 02:42
  • By BarrenForklift
key on, pump pedal 3 times, count engine light flashes (first flashes of 1 and 2 do not count) fault codes are two digit numbers (71 ,72 ,74 etc) probably need to clean mixer and vaporizer ,to clear codes(pump pedal ten times within 5sec.)if codes do not reset your problem is solved
  • Posted 13 Nov 2012 12:45
  • By snowmonkey
  • Alberta, Canada
March 25th-26th, 2026 - Ho Chi Minh City, Vietnam
March 31-April 2, 2026 - Paris, France
April 22-23, 2026 - Atlanta, United States
edition #1264 - 15 January 2026
In this week’s Forkliftaction News , we look at the top five robotics trends forecast for 2026 from the International Federation of Robotics, and it’s an eye-opening read with the potential for robotics, AI and automation to work together to change our sector in fundamental ways... Continue reading
Australia was the first nation to successfully convert its paper-based currency to polymer banknotes, a technology developed in the same country. The first polymer banknote was a commemorative $10 note issued in 1988 to mark the Bicentenary. The first polymer banknotes were also the first to feature a transparent "window" as a security feature.
Taylor THC500L
Enforcer FLBAXT25
Claire Grossmann Claire Grossmann
Secretary general , FEM - European Materials Handling Federation
Chief revenue officer, Corvus Robotics
EVP corporate affairs & brand, Konecranes
Senior vice president, Crown Equipment
Arnold, MO, United States
