Electric forklift E16S 324 series
I need help.
Our forklift don't move forward and back. But sometimes it working a little (it move forward and back a little and stop) I turned off supply and turn on it again then I press the forklift's pedal forward the forklift moves a little and stop. I press the pedal again the forklift don't move at all. What's problem in?
Best regards
  • Posted 14 Aug 2017 03:49
  • By nik_n
  • joined 14 Aug'17 - 5 messages
  • Murmansk, Russian Federation
The contactors should be checked
If they are normal check carbon in engines,
If OK, check 111RZR modules
  • Posted 20 Nov 2020 18:40
  • By rotemj
  • joined 3 Aug'19 - 10 messages
  • israel, Israel
rotem.J
Pinalitan kona ng steering pot at steering sensor Sir ganon pa din. Ung right side lang ung gomagana pero mahina at nag jejerking, naka straight ung steering wheel
  • Posted 25 Aug 2017 02:06
  • By Jorne
  • joined 2 Dec'16 - 27 messages
  • Jebel ali dubai, United Arab Emirates
[email address removed]
  • Posted 24 Aug 2017 19:42
  • By Jorne
Email address mo mate?
  • Posted 21 Aug 2017 23:49
  • By RomMel
  • joined 8 Jun'17 - 10 messages
Please check the steering sensor is working if ok check the power module of the motor that is not working then if ok check the contactor contact point.
Regards Rolly
  • Posted 19 Aug 2017 04:02
  • By rolly
  • joined 15 May'14 - 89 messages
  • Manama, Bahrain
Lifting is okay Sir.
Steering also function but Hyd. MOTOR to Much sound Coming.
  • Posted 18 Aug 2017 16:11
  • By Jorne
Check handbrake switch.
Voltage across battery when under load
Linde's tend to self check all their systems before moving, so if there is a fault with steering or hydraulics, they will not move.
  • Posted 18 Aug 2017 08:16
  • By BurtKwok
  • joined 1 Apr'12 - 49 messages
  • West Yorks, United Kingdom
fully charge is not really a valid statement
many problems are battery related what we need is the voltage loaded meaning if your meter is connected across the battery with lift or drive what does the voltage drop to
  • Posted 17 Aug 2017 06:52
  • By forkguy
  • joined 25 Jul'17 - 28 messages
Baka pwidi mo akong matulongan Sir anong problema ng linde forklift.
Salamat.
  • Posted 17 Aug 2017 00:27
  • By Jorne
Opo filipino Sir
  • Posted 17 Aug 2017 00:24
  • By Jorne
Filipino?
  • Posted 16 Aug 2017 23:01
  • By RomMel
Sir Mikel, i have same problem of lindi E16 tri wheel,
The problem is slowly moving the right side drive wheel ang the right side is no moving while i hang up the both drive wheel. I have no manual for reference guide, before that the problem i calibrate the steering potentiometer manually using digital multi Meter at that before the function is Normally. Okay, but today again same problem coming. What should I do Sir?
Thank you very Much
  • Posted 15 Aug 2017 02:39
  • By Jorne
The battery on forklift is fully charged. The forklift loses movement suddenly. I press on the forklift's pedales several times The forklift don't move at all. I turn off supply, switch it on again. press about 5-6 times and forklift start moving. The seat switch is absent. Its contacts are connected directly.
  • Posted 14 Aug 2017 19:18
  • By nik_n
start whit good look to baterie
  • Posted 14 Aug 2017 04:45
  • By michel_v
  • noord holland, Netherlands
Terberg YT220
Maxlion R2B25LI
Bolzoni SpA (Group HQ)
