EKS308 code E0701
If the key switch is turned on and the unit goes thru self test then gives this code check this. Turn key switch off then back on, listed for the steering to cycle thru, if the steering does not cycle thru check the 10amp fuses on the controller. If the 10amp fuses are good pull the cover off the controller and check the 250amp and 450amp fuses. Our techs have been finding these fuses are open and bluish in color. Check battery both static and load test. Not saying this is the end all to fix this problem but a good place to start.
  • Posted 15 Oct 2016 08:49
  • By tyler_d
  • joined 23 Sep'16 - 79 messages
yes of course this is normal you must now change the values ??in the parameter service
and of course you must know the procedure of this last good try otherwise you can contact me to solve the problem even remotely
whatsup number
+212663576104
  • Posted 1 Oct 2020 10:11
  • By imad_b
  • joined 8 Dec'17 - 47 messages
  • oulfa, Morocco
imadi.bakhat@gmail.com
+212663576104
crdt
Hello sir
I have one issue with jungheinrich eks 210 showing the same error 0701 iam changed the jxp safe card and all parameters set with safe controller but still 0806 3 showing the error log serial no. Not matching how can possible to match the serial no. Via judit
  • Posted 1 Oct 2020 02:43
  • By Nikku
  • joined 1 Oct'20 - 2 messages
  • United Arab Emirates
Nisu
Y MUST CHANGE THE JXP SAFE (SMALL CARD IN THE BACK OF TRACK)
  • Posted 27 Jun 2019 08:29
  • By imad_b
  • oulfa, Morocco
Uxbridge, Canada
Evansville, IN, United States
St. Louis, MO, United States
Daleville, IN, United States
US confidence index rises sharply Washington, DC, United States
