Toyota 7FGU25, 63234, mast V type. This standard mast truck, w/out s/s, needs a main hydraulic steel line. This steel line runs on the right side hoist cylinder, then 90 degrees to a fitting. The fitting has some SAS wires and sensor. I need the P/N for the steel line.
Thank you.
Γιάννης από την ¨Σπαρτη
