E07-1 displayed
I have an error code of E07-1. Truck serial number is 32649. Need how to repair and reset. Does anyone have a cd for this unit?
  • Posted 5 Nov 2013 08:54
  • By jim_v
  • joined 26 Aug'08 - 61 messages
  • Michigan, United States
Last Year I ran into a few of those. Same problem, harness to tight causing wire to break...
  • Posted 5 Apr 2016 06:43
  • By art_flo
  • joined 20 Jan'16 - 7 messages
Just to confirm I found same broken wire in my 8 series and it's been good ever since.
  • Posted 28 Feb 2016 00:54
  • By troy_m
I have the same E07-1 code and found the same it would run with the lp valve out and plugged off. My customer only has 6500 hours on their Toyota but this machine has been a lemon since they bought it. So many problems like this. I'm not impressed with Toyota's recent model. Nothing like an old Carbed 4Y eh. I'm glad you found a broken wire in the harness because that's my next step. Thanks for keeping us posted.
  • Posted 10 Feb 2015 12:25
  • By troy_m
A-Lift Services -- safe -reliable -affordable
Solved!
Engine would run with fuel mixture ratio motor removed from Lp inlet at carb. And plugged with hand.
Cut harness open and found broken wire (red/blue stripe) at main harness clamp above cyl. # 3.
Lift had 14422 hrs on it so the wiring harness had some wear.
I spliced wire back and bingo! Prob. Solved.
Code went away and cust. Happy so I'm happy.
Hope this helps someone else
  • Posted 15 Aug 2014 00:09
  • By FootHill
  • joined 9 Dec'12 - 14 messages
Be safe out there!
Pmslift@aol.com
Just looking for as much info on this as I can get.
So few questions.
1) what is "25"reference to? Ohms resistance?
2) "just means throttle body is wet" wet with what? And why would it be wet?
  • Posted 10 Aug 2014 15:33
  • By FootHill
Be safe out there!
Pmslift@aol.com
It just means the throttle body is wet. Let it dry or dry it and the code will disappear
  • Posted 10 Aug 2014 05:01
  • By jim_v
Ok I've got same code.
What is 25 a reference to?
Ohms?
Thanks in advance!
  • Posted 9 Aug 2014 01:04
  • By FootHill
Be safe out there!
Pmslift@aol.com
Air fuel ratio motor open. Start with checking wiring. Testing the motor: The following will have 25 +-5 at 50-100 degrees celsius. 20 +-5 at -10-50 degrees celsius. PIN 1-2 Pin 2-3 Pin 4-5 Pin 5-6. If problem not found here at the motor then wiring harness or controller.
  • Posted 24 Jun 2014 12:24
  • By Bulldog965
  • joined 15 Oct'09 - 63 messages
  • Indiana, United States
Richard
Sue Tomic Sue Tomic
