Drives forward, but not always in reverse
I Have a Yale GLP040AF which often times will only go into after slamming body backwards against seat while shifting into reverse. Any thoughts or suggestions?
  • Posted 29 Oct 2022 04:39
  • By Eric_Wilson
  • joined 29 Oct'22 - 1 message
firstly, check you fwd/rev signals at the control valve solenoids, also check the switch/s at the directional switch.
If all is ok in both of those areas and the electrical is good then you'll have to check pressures and see if it's a clutch pack issue.
  • Posted 30 Oct 2022 15:31
The hardest substance in the human body is tooth enamel. Its main component, apatite, ranks at level 5 on the Mohs scale of mineral hardness - harder than gold, silver, iron, or (mild) steel.
Philadephia, PA, United States
Chandler, United States
Steve Nation Steve Nation
Senior solutions sales engineer, Numina Group
President, International Federation of Robotics
VP of Corporate Remarketing, Alta Material Handling
Chief executive officer, Peak Technologies
Tusk 500PGH16
Terberg RT223
