Drive wheel removal
Can Anyone guide me on how to remove the drive wheel on a 20mt. The gears are preventing me from removing the axel. Looks like I have to remove the large upper gear in the gearbox. Do I have to remove the bearing on the end of that shaft or does the shaft come out whole?
Thanks in advance.Rich
  • Posted 23 Apr 2025 05:34
  • By Rich_Ariola
  • joined 23 Apr'25 - 1 message
  • Nevada, United States
RICH
On the shorter end of the drive unit there is a case held in place by 4 bolts. Removed that case and you should see a nut with a cotter pin. Remove that nut and bearing cone. You can now hit that shaft toward the other side. **Do not hit it out all the way**. Once the drive tire is able to fall down, you do not need to take the shaft any father. This shaft goes through a gear in the gearbox and if you fully remove the shaft it can be a pain to get it realigned.
Reverse the steps to install the new drive tire. To line it up and get the shaft all the way back in you will need to twist the shaft until the woodruff key lines up to the slot in the gear.
  • Posted 30 May 2025 02:06
  • By DyslexicNerd_01
  • joined 13 Jun'23 - 228 messages
  • Wisconsin, United States
edition #1277 - 16 April 2026
In this week’s Forkliftaction News , we look at how automation continues to be an area of rapid advancement for the materials handling sector, as we saw at LogiMAT 2026, but not everyone is convinced of its value - yet... Continue reading
Justin Byma Justin Byma
VP global product manager and strategy , Hyster-Yale Materials Handling
Chief operating officer, TVH Americas
Chief financial officer and treasurer, Universal Logistics Holdings
Director of aftermarket, Noblelift North America
JLG launches YouTube University channel McConnellsburg, PA, United States
Around 8-10% of people grind their teeth at night. The process is called sleep bruxism, and most people aren't even aware they're doing it.
