Drive unit failure
Has anyone else been having issues with the drive unit? We have had several failures of the snap ring which holds the Gear Assembly into the drive plate housing.
  • Posted 16 Mar 2009 01:15
  • By Truck_Tech
  • United States
You do not need to remove the mast to repair the snap ring......the first reduction gear, bearing and new snap ring can be had as a kit....when installing the new stuff use green lock tite in the houseing bore where the bearing seats....we have had instances where the outer race of thebearing was moving in the housing, causing noise....green lock tite is made for permantely installing studs and bearings
  • Posted 16 Aug 2013 01:24
  • By theforkliftdude
  • joined 7 Jan'11 - 14 messages
  • Wisconsin, United States
We have had numerous snap ring failures and have found that the debri in the gearbox will get picked up and damage the output gear on the drive motor armature which is non replaceable. be sure and check the gear on the drive motor anytime you have a snap ring failure.
  • Posted 30 Oct 2010 07:21
  • By bruce_c
  • joined 28 Jul'10 - 52 messages
  • Missouri, United States
Crown says that there was a defect in the snap ring. The drive units we've tried to fix, with the new snap ring and bearring, still make a lot of noise. We ended up replacing the whole drive unit assembly, motor and all. I sure hope they can get this problem fixed soon, but from past experiences with the engineering dept., it takes forever to come up with a solution.
  • Posted 23 Mar 2009 22:44
  • By Truck_Tech
  • United States
i believe the only trucks affected by this are the early built ones, up to feb. '08 models. what i did and which seems to have worked cuz there has been no problems after the repair was massage the retianing ring and groove to help seat the ring as best as possible. i'm thinking when the ring was stamped it may have been out of spec. i hope this may help! you can also try crown tech. support and see if they have any answers for you.
  • Posted 20 Mar 2009 09:28
  • By crowntech
  • joined 27 Jun'07 - 9 messages
  • Illinois, United States
Has been an issue. Several failures, leading to major warranty work for the shop. I understand you have to remove the mast from the unit!!
  • Posted 19 Mar 2009 13:23
  • By tonymfg
  • joined 16 Jan'09 - 43 messages
  • New Jersey, United States
Aichi SR18A
Terberg RT223
edition #1285 - 11 June 2026
Aichi SR18A
Terberg RT223
Aichi SR18A
Terberg RT223
