have a M40D cat, s/n 4WC01746. No manual.
Have run the diagnostics and everything is ok. The problem is when you step on the accelerator pedal, unit creeps, then takes off. Happens same way forward or reverse.
Checked the drive motor, SCRs, and replaced the throttle control.
Would like a repair manual or if anyone has had this problem
