Doosan won’t pull its self up loading ramp
Latish doosan 2.5 tonn diesel truck won't pull its self up loading ramp will drive on the flat ok this happened suddenly so don't think it's tourney converter changed transmission filter to no avail
  • Posted 23 Jun 2020 21:58
  • By Peter_Jeffery
  • joined 23 Jun'20 - 2 messages
  • Cambridge, United Kingdom
P jeffery
No problem Peter, glad you got it sorted.
  • Posted 26 Jun 2020 15:53
  • By simon_k
  • joined 31 Oct'04 - 149 messages
  • Devon, United Kingdom
Hi Simon
You were spot on with that it was only just lose not half a turn but it has sorted it
thanks peter
  • Posted 26 Jun 2020 01:54
  • By Peter_Jeffery
P jeffery
Hi Peter, On the back of the valve chest on top of transmission there is a big cover plug with hex head. Take that out and remove valve spool behind. In the end of that spool is a little nylon screw in filter. These have a habit of coming loose and stopping full travel of valve causing transmission slip. Even a quarter turn loose makes a big difference so definitely worth a check.
Cheers,
Simon
  • Posted 25 Jun 2020 16:46
  • By simon_k
Cortney Hunt Cortney Hunt
COO, Intelligrated, Trew and Transnorm
Automation manager, N.C. Nielsen
September 29-01 October, 2026 - Cairo, Egypt
October 6-7, 2026 - London, United Kingdom
