Doosan G25P-5
Does any one have any information on the woodward fuel system. Have a unit that will not start unless you remove the orifice mounted on the side of the carb. housing. If you remove the orifice fitting and install a non restricted fitting, unit will run but will backfire through air filter under a load. This has the tier III emission. It has 2 trim valves is there a way to test the trim valves. Regulator was replaced due to the oil build up. I have no information on these units, Thanks. Model#G25P-5 Serial #ML-00805.
  • Posted 25 Apr 2013 16:18
  • By GregM
  • joined 2 Apr'12 - 26 messages
I received the info, thanks.
  • Posted 3 May 2013 12:34
  • By jason_g
  • joined 18 Apr'11 - 31 messages
  • Illinois, United States
Would you be able to forward that information to me?
  • Posted 29 Apr 2013 22:02
  • By jason_g
Recieved some information on the woodward fuel system from another member that sent me in the right direction. Waiting on parts. Thanks to all for the info.
  • Posted 28 Apr 2013 06:29
  • By GregM
If the engine light is on you can pull flash codes by turning the key on and pumping the pedal three times in three seconds. This might help point you in the right direction.
  • Posted 27 Apr 2013 00:13
  • By jason_g
