does any one have manuals for the c5000 cat?
it is lp
cranks but no start.
another shop gave up on a repair.
they did new vaporizer new starter.
just starting on this repair, with new battery.
I did a quick check on the fuses they all check ok.
I am thinking interlock on the fuel or spark.
I need a wiring diagram.
  • Posted 7 Jan 2020 15:49
  • By iowagold
  • joined 7 Jan'20 - 14 messages
  • Iowa, United States
Thanks Paul in Iowa
http://www.poustusa.com
the best way to figure out what is wrong is to hook up the diagnostic pc (diagnozer) program and see whats going on.
Otherwise if there is anything wrong it should be showing an error code on the display in the hour meter LCD window.
The LP interlock is actually part of the vaporizer and since that was replaced i doubt that's what is wrong.
You can look at the LP injector, pull it out and see if it is oily and dirty. Also check the inline fuse link in the harness going to it, there is a small black square fuse holder with a minifuse in it on the side of the injector body.
What is the serial number of the lift?
  • Posted 7 Jan 2020 17:23
Ancient Egyptian civilization lasted for so long - over 3,000 years - that by the time of the New Kingdom (c. 1550-1070 BCE) Ancient Egyptian archaeology was a career option.
edition #1284 - 4 June 2026
It has been a big week of product launches for the materials handling sector... Continue reading
