Dies when making a fast right turn.
Forklift runs good, unless you make a fast right hand turn then it dies and beeps while low oil pressure light comes on. Starts back up fine. I also added another ground thinking its pulling on the ground strap. Didn't make a difference.
  • Posted 3 Mar 2017 03:33
  • By Kruziik
  • joined 3 Mar'17 - 7 messages
  • WA, -
No shorts in both circuits. Also checked ignition circuits for shorts as well.
  • Posted 4 Mar 2017 05:13
  • By Kruziik
  • WA, -
Ill check, but wouldn't the light go off as a warning before shutting off.
  • Posted 4 Mar 2017 03:51
  • By Kruziik
  • WA, -
ok...
i know you checked the engine oil level yes?
if thats ok then i'd check for shorted wiring from the oil level sensor circuit?
it may be up against something shorting out the circuit when you turn.
  • Posted 3 Mar 2017 23:57
  • Modified 3 Mar 2017 23:58 by poster
