diagnostic access
Does someone have the sequence to access the onboard diagnostic? Customer lost the manual for this unit. I remember it took a couple of steps to get it. Thanks for any help.
John
  • Posted 5 Feb 2015 08:48
  • By BREWSKI
  • joined 10 Jan'12 - 1,698 messages
for the toyota 6BPU15 order picker is it possible to set the horn to the continuous beeping like the newer models?
  • Posted 24 Jul 2024 00:54
  • By Judd_Lessman
  • joined 24 Jul'24 - 1 message
  • Illinois, United States
Hola orozco, conoces cual es el password de toyota 6bncu15?
Edited by Admin....please do not ask for passwords. Forkliftaction does not condone the sharing of passwords................
mi pregunta es cuales son esas palabras clabe para accesar al diagnostico y reset ?
  • Posted 16 Jan 2016 18:57
  • Modified 17 Jan 2016 23:10 by administrator
  • By sam_radiation
  • joined 14 Jan'16 - 2 messages
  • Nuevo Leon, Mexico
Entering the Primary Password
1. Press the power control and hour meter
select switches simultaneously (system
should respond with a short beep).
2. Within 10 seconds, press the UP arrow
(system should respond with a short beep).
3. Within 10 seconds, press the DOWN arrow
4. Within 10 seconds, press the UP and
DOWN arrows simultaneously and hold
them for 2 seconds (system should respond
with a short beep after 2 seconds).
Acceptance of the primary password will be
indicated by the word "PRIMARY appearing on
the display. If a switch is not pressed within the
10 second limit, the system will default back to
the self-diagnosis mode.
Analyzer (AnL) Mode
Analyzer mode is the error analysis mode. Both
primary and secondary passwords are required
to enter analyzer mode. Once the analyzer mode
is activated, the display will show "Analyzer".
Entering the Secondary Password
1. Enter the primary password.
2. Within 10 seconds, press the power control
select switch (system should respond with a
short beep).
3. Within 10 seconds, press the UP and
DOWN arrow switches simultaneously
"Analyzer" will appear on the display indicating
acceptance of the secondary password.
Entering Analyzer Mode
To enter Analyzer Mode, press the power control
switch. The 8-character display will display
"AnL" in the left most segments and the right
most segments will display "00". The left "0" will
be flashing. The left number is the category
number, the right number is the class number.
  • Posted 27 Feb 2015 08:07
  • By orozco
  • joined 24 Feb'15 - 4 messages
  • NUEVO LEON, Mexico
edition #1294 - 13 August 2026
In this week’s Forkliftaction News, we report on Jungheinrich’s H1 financial results and the reasons it has adjusted down its EBIT forecast for the year... Continue reading
September 9-11, 2026 - Hanoie, Vietnam
September 16-17, 2026 - London, United Kingdom
