Dead forklift: fault codes 677-3 and 2000-12
Hi all. Fault codes 677-3 and 2000-12 are displayed. Engine doesn't starts, no power on starter relay coil. What does these codes means? 667-3 is probably something with starter relay driver... but 2000-12?
Another problem, when fuse F6 is in, the horn sounds continously when the battery is connected. There are no shorted wires from horn button.
  • Posted 20 Jul 2011 16:06
  • By ArtB
  • joined 11 Mar'11 - 7 messages
  • Śląsk, Poland
I have had a weak battery give this code as well as an over charging alternator.
  • Posted 22 Feb 2019 07:38
  • By PESLLC
  • joined 10 Oct'13 - 35 messages
  • fl, -
DC
The horn on these trucks are three wire. There is a batt. pos. and a batt. neg. And a signal wire from the VSM. Check the wiring at the horn and test the out put wire for a pos. signal from the vsm. If no signal replace the horn. If there is a signal and the horn button is not stuck you have a defective vsm.
  • Posted 27 May 2016 05:11
  • By BREWSKI
  • joined 10 Jan'12 - 1,698 messages
677-3 is a voltage high on the driver output. Check the wiring for shorts to battery pos. Is this keyless start truck? If it is check the disconnect switch under the hood.
  • Posted 27 May 2016 05:08
  • By BREWSKI
Check 20amp fuse in the box next to battery. If that has blown you wont get any gas through the chamber an no spark.
  • Posted 21 May 2016 17:37
  • By luke_m
  • joined 2 Feb'13 - 97 messages
  • Bedfordshire, United Kingdom
ArtB,
You have a Canbus Error that may be inhibbiting the vsm starter driver.
Clear the error log and see if the truck now starts,
Titus
  • Posted 22 Jul 2011 05:09
  • By Titus
  • joined 6 Jul'10 - 185 messages
Ancient Egyptian civilization lasted for so long - over 3,000 years - that by the time of the New Kingdom (c. 1550-1070 BCE) Ancient Egyptian archaeology was a career option.
edition #1284 - 4 June 2026
It has been a big week of product launches for the materials handling sector... Continue reading
Noblelift
