daewoo d30s-3 trans / axle oil
can anyone tell me what oil to put in a daewoo d30s-3 front axle / transmission. thanks.
  • Posted 31 Oct 2013 07:49
  • By markg
  • joined 27 Oct'09 - 57 messages
  • n lincs, United Kingdom
here is what I found for your truck: Direct from Manual
Drive Axle Oil:
NOTE : Failure to follow the recommendation will cause shortened life due to excessive gear wear.
Select oil that meets below specifications.
API GL-5
MIL-L-2105C, D
Transmission Oil:
NOTICE
This oil is formulated for transmissions and drive trains only, and should not be used in engines. Shortened engine life will result.
NOTE : Multi-grade oils are not blended by DAE- WOO for use in transmissions. Multi-grade oils which use high molecular weight poly- mers as viscosity index improvers lose their viscosity effectiveness by permanent and temporary shear of the viscosity index improver and therefore, are not recom- mended for transmission and drive train compartments.
NOTE : Failure to follow this recommendation can cause shortened transmission life due to material incompatibility, inadequate fric- tional requirements for disk materials and/ or excessive gear wear.
The API CD/TO-2 specification or MIL-L-2104D or E oil could be used.
  • Posted 31 Oct 2013 08:33
  • By kevin_t
September 4, 2025 - Melbourne, Australia
September 17-18, 2025 - Miami, FL, United States
October 21-23, 2025 - Barcelona, Spain
Highland, IL, United States
Tacoma, WA, United States
Dallas, TX or Lexington, KY, United States
Orlando area, United States
SMV (Konecranes) 33-1200C
Ncn 85TH
Ncn 85TH 2017
Jan Zuurbier Jan Zuurbier
Global CEO, Swisslog
Board member, UKMHA
Strategic advisor, Roboteon
CEO Americas, Hai Robotics
