Daewoo B30S reverse alarm
Where is the best place to wire in a reverse alarm on a Daewoo B3S, Is it best to take a feed off the direction switch and then through a relay or from the direction contactor coil through a relay? What voltage relay is best? the truck is 80v but im not sure if the control circuit has reduced vaoltage.
  • Posted 15 Apr 2013 19:44
  • By Leon_W
  • Tyne & Wear, United Kingdom
What is the direction contactor coil voltage on a 80v truck?
  • Posted 17 Apr 2013 20:13
  • By Leon_W
Hi Leon,
If it has the same direction switch as the early daewoo trucks it should have an auxiliary reverse switch, so you can connect it to a fused supply and use that for the reverse alarm.
  • Posted 16 Apr 2013 05:52
  • By controlelectric
  • joined 8 Dec'08 - 70 messages
  • Shropshire, United Kingdom
if there is a spare switch at the direction lever will it be full battery voltage?
  • Posted 16 Apr 2013 01:50
  • By Leon_W
On B13-18 models the back alarm is usually feeded thruogh DC_Dc converter, but check directional lever assy I think you have an extra switch there to fit the alarm.
Regards
  • Posted 16 Apr 2013 00:01
  • By nacsand_n
  • joined 20 Sep'09 - 716 messages
  • Madrid, Spain
Deborah Baker Deborah Baker
