D-FET short 408 error
Hi guys.
Maybe you could help me with this problem.
After turning the key switch on, the display says "D-FET short 408" error and the forklift doesn't power up.
Somebody knows what this is?
  • Posted 16 Jan 2011 10:58
  • By ivanlinaric
  • joined 16 Jan'11 - 110 messages
  • Zagreb, Croatia
Showing items 1 - 20 of 29 results.
hi eslam did you solve this problem? the 412 event on your nissan i got same fault, much appreciate if you can help me with this code thanks
  • Posted 30 May 2022 17:09
  • By macky03
  • joined 18 Jul'18 - 5 messages
  • New Zealand
macky
Hi
I have the same error code ( check D-FET FOR LH Short 410).If you already solved your problem please let me what is the reason for this error and how can I solve it?
Best Regards
  • Posted 10 Apr 2021 22:24
  • By eslam_a
  • joined 10 Mar'19 - 1 message
  • Egypt
eslam atef
sir i have nissan electric forklift model;SINILI5Q
display show , check D-FET FOR LH SHORT 410, help me.
  • Posted 8 Jul 2017 18:49
  • By noman_a
  • joined 8 Jul'17 - 3 messages
  • jeddha, Pakistan
hey guys I'm having problems with error 455 can some one help me the display shows the wheels in the right angle
  • Posted 2 Jun 2016 02:00
  • By reyes_m
  • joined 2 Jun'16 - 1 message
  • tamaulipas mex., Mexico
Hello
I had same problems fault 408 ,replaced D fet module after error 406 capacitor board.What problem with capacitor board(bad connection?)
  • Posted 24 Jul 2015 14:07
  • By margo_k
  • joined 28 Jul'10 - 17 messages
  • Pärnumaa, Estonia
bonsoir
non il n'y a pas de paramètre a faire après le changement d'une carte most
  • Posted 11 Jan 2013 07:33
  • By assane_s
  • joined 17 May'12 - 15 messages
  • toulouse, France
non pas besoin de parametrage seulement il ne faut pas les inverser. en plus besoin de changer tout les deux cartes
  • Posted 9 Jan 2013 22:28
  • By assane_s
  • toulouse, France
Profile update !
Thank you everybody
  • Posted 9 Jan 2013 08:23
  • By Muchas_T18
  • joined 1 Dec'11 - 3 messages
  • BDR, France
MasterDiag LINDE ! muchas13@hotmail.com
muchas T18; If you have your e-mail listed in your forum profile you just may find it useful. A picture, as they say is worth a 1000 words.
  • Posted 9 Jan 2013 06:59
  • By MEngr
  • Missouri, United States
Sorry I just saw your message....
Looks like assane explaind everything.
By the way guys, use english.
Don't privateze the thread.
  • Posted 9 Jan 2013 06:40
  • By ivanlinaric
  • Zagreb, Croatia
Ok, merci assane_s, c'est donc bien la partie puissance qui fait défaut... !
Y'a t-il un paramétrage spécifique a faire si l'on décide de remplacer une des deux carte de MOS ?
  • Posted 9 Jan 2013 05:47
  • By Muchas_T18
  • BDR, France
la carte se trouve tout a fait au fond il faut enlever la carte de commande apres la carte ou il y a des condensateur et vous trouverez deux cartes avec des mos ranger de neuf
  • Posted 9 Jan 2013 05:30
  • By assane_s
  • toulouse, France
  • By assane_s
  • toulouse, France
hi Ivanlinaric !
I also have the error "short 408" but I do not understand where is the card "D-FET"?
The problem is on the card control or card power ?
Best regards
  • Posted 5 Jan 2013 21:23
  • By Muchas_T18
  • BDR, France
mail: azoosamb at yahoo dot fr
  • Posted 10 Oct 2012 21:03
  • By assane_s
  • toulouse, France
thank my mail : [email address removed]
  • Posted 10 Oct 2012 21:00
  • By assane_s
  • toulouse, France
Need more help?
  • Posted 9 Oct 2012 20:50
  • By ivanlinaric
  • Zagreb, Croatia
Service technician.
Feel free to contact me at ivan.linaric@okretnimoment.hr
Hello Assane,
sorry I can't post any documentation here...
Regards
  • Posted 9 Oct 2012 19:01
  • Modified 9 Oct 2012 20:49 by poster
  • By ivanlinaric
  • Zagreb, Croatia
thank you very much Ivanlinaric(the problem comes from the inversion of UR and WR )
but i have already the fault 412 I wantto know how to test the big transistor MOST FET of the pump I hanve't no manuals for this truck
  • Posted 5 Oct 2012 07:46
  • By assane_s
  • toulouse, France
Hello assane_s,
in my table of errors I have this information:
error 405 - battery voltage - over voltage
error 416 - drive current sensor - V phase low output
*error 405
1. check the battery voltage
2. check the main cables to traction board
3. check the batteries and battery compartment
4. looking in to the schematic, the only device that could be measuring voltage is the traction board itself, so if 1, 2 & 3 is OK you could have a faulty board.
*error 416
The drive current sensor is actually just a coil around the V phase of right drive motor. It picks up magnetic field from passing current in the cable and obviously creates a small current that can be measured by the traction board.
1. Check continuity (OHM) of the coil
2. Check power supply and wiring to the coil
3. looking in to the schematic, the only device that could be measuring current is the traction board itself, so if 1 and 2 is OK you could have a faulty board.
I hope I have helped you.
Regards.
  • Posted 3 Sep 2012 18:53
  • Modified 3 Sep 2012 18:54 by poster
  • By ivanlinaric
  • Zagreb, Croatia
Andreas Schneider Andreas Schneider
Managing director sales & service, STILL
Executive vice president people & culture, Konecranes
Vice president of operations, Hangcha Forklift America
Senior solutions sales engineer, Numina Group
