Cylinder issue
Hello,
I have a Crown reach truck that the free lift cylinder raises about half way up, then the second stage starts to raise if i go full speed. if i go up slowly then it stages properly. Any help would be greatly appreciated.
  • Posted 7 Oct 2021 05:07
  • By ChrisCrown
  • joined 7 Oct'21 - 3 messages
  • Virginia, United States
I've had this problem before. it was the flow regulator.
Question , I have a 5700 It has passed the main lower valve calibration. It cushions fine coming back down into free lift.
does not have that cushion at the bottom of the carriage cylinder.
I have the manual and have been looking at the flow regulator. I also see a compression spring. And shut off valve?
Do you think the flow regulator would cause this lowering issue?
  • Posted 28 Jan 2026 23:06
  • By BigAl88246
  • joined 5 Apr'17 - 15 messages
Send me an email and I will reply with parts breakdown. My address is in the signature block below.
  • Posted 12 Oct 2021 05:52
  • By 1CrownTech
  • Washington, United States
1crowntechnician@gmail.com
Thanks for your help! Do i have to remove the cylinder or chain up the carriage to get to it?
  • Posted 12 Oct 2021 05:38
  • By ChrisCrown
The flow regulator in the bottom of the carriage cylinder is bad.
  • Posted 11 Oct 2021 14:36
  • By 1CrownTech
March 16-18, 2027 - Stuttgart, Germany
October 26-27, 2026 - Fort Shelby, Michigan, United States
