CUTS OUT
hi ,R14 G1X115NOO494 , EVERYTHING WORKS FINE BUT WHEN A LOAD IS ON THE FORKS AND BRINGING THE REACH IN ONLY ,THE MACHINE CUTS OUT ,RESET IGNITION AND THEN WORKS FINE FOR A WHILE , NO PROBLEM WITH REACH GOING OUT ONLY COMING BACK IN.
PETER
  • Posted 21 Dec 2016 03:14
  • By peterb
  • joined 23 Feb'16 - 125 messages
  • lancashire, United Kingdom
I would suggest to check the voltage dropped and coil resistance of the reach in valve coil in the control valve.
Do you have truck doctor diagnostic?
Did you get any error codes?
  • Posted 24 Dec 2016 03:55
  • By melvin_p
  • joined 25 Nov'16 - 15 messages
  • QUEZON PROVINCE, Philippines
hi,the reach cuts out ,only when a load on the forks and only when reach coming in ,not out
  • Posted 21 Dec 2016 19:41
  • By peterb
do you mean the reach cuts out or the truck
  • Posted 21 Dec 2016 04:56
  • By alanmitsi
  • joined 8 Aug'13 - 151 messages
  • essex, United Kingdom
Michel Denis Michel Denis
