Crown SX3000 drive fault
Hi All,
Have a Crown SX3000 that turns on line contractor comes in and drives fine.
But if you press the lift the line contractor drops out and truck won't drive but the hyd still work fine rekey and truck will drive as much as you like until you lift
Any help would be good
No fault codes
  • Posted 31 Aug 2023 03:37
  • Modified 31 Aug 2023 03:37 by poster
  • By Jack_Coss
  • joined 10 Apr'21 - 3 messages
Always happy to help
Sounds about right. Might just be one battery that is dead sucking power from the others.
  • Posted 1 Sep 2023 02:23
  • By DyslexicNerd_01
  • joined 13 Jun'23 - 226 messages
  • Wisconsin, United States
Turns out to be bad battery's
  • Posted 1 Sep 2023 02:15
  • By Jack_Coss
With no error code it sound like there might be a bad fuse. If the truck were to close the contactor it would throw a code. Sometimes a fuse can blow up still allow low current to pass thru. Try removing that fusecand testing the resistance. Otherwise the tips on the contactor might be burnt.
  • Posted 31 Aug 2023 03:46
  • Modified 31 Aug 2023 03:47 by poster
Briefs United States
Nagano NUZ090D
Hoist Liftruck F180-36BOX-CAR
Nagano NUZ090D
