crown sp3020
i have a crown unit that throws a code 217 every once in a while i have change both encoders and pcb board. some one told me that the display module cuts off the signal to the steer controller and replace it. Just want to confirm before purchasing. And yes i have the terminal hanset and set to the correct parameters.
  • Posted 21 Feb 2009 08:43
  • Discussion started by ben_g
thanks for the info richierich. It ended up being a intermitting signal lost from steer module to encoder. swapping the module took care of the problem. I will keep in mind for the future what you suggested thanks again.
  • Posted 3 Mar 2009 09:39
  • Reply by ben_g
If the module swap does not work for you. I have had a similar problem, it ended up being the upper drive unit bearing. Would need to drop the drive unit and remove the drive motor to have access to the pilot holes to remove bearing form power unit.
  • Posted 3 Mar 2009 09:20
  • Reply by richierich
  • Maryland, United States
Forklift Technician
yes. I will try that next thanks
  • Posted 23 Feb 2009 02:04
  • Reply by ben_g
Do you have a sister truck,that you can swap display and/or steer modules with?
  • Posted 23 Feb 2009 01:54
  • Reply by Truck_Tech
  • United States
I have also replaced the k-5 relay no such luck. also check mast cables. It is one of the those fun intermitting deals. Check connections.
  • Posted 22 Feb 2009 14:26
  • Reply by ben_g
I would check the K5 relay(Part#100326) tip,and make sure they are not pitted/burnt. It's behind the plastic cover,just above the steer module.
  • Posted 22 Feb 2009 14:09
  • United States
GemOne
Toyota 8FBE20U
Flesherton, Ontario, Canada
Morooka MFD20
Lift Technologies Inc.
Hyster
Harrisburg, SD, United States
Ottumwa, IA, United States
Wentzville, MO, United States
