crown sp3020-30 code 213
I have a crown sp3020-30 that is coding out 213, any idea's.
Thanks
  • Posted 5 Jun 2013 07:13
  • By LeRoy_H
  • joined 5 Jun'13 - 3 messages
Steering fuse (FU10) is blown.
EVENT CODE 213
Steering, traction and lift disabled.
Step 1:
Check fuse FU10.
If: FU10 is bad.
Then replace.
If: FU10 is good.
Then check wire #2941 between FU10 and CA407-2 also wire #518 between CA407-4 and negative bus for
loose connections.
If: Connection is bad.
Then repair.
  • Posted 6 Jun 2013 22:50
  • By ivan_j
  • joined 16 Feb'11 - 65 messages
Deborah Baker Deborah Baker
